Unwanted Edges
8308.1
Hey guys,
Any one of you wizards know how to get rid of Unwanted/Unneeded Edges without having to rebuild the entire surface?
I sometime get left off with extra edges after executing booleans operators.
I was wondering if there was a clean way to eliminate the unneeded edges.
Bests,
-Berube
8308.2 In reply to 8308.1
8308.3 In reply to 8308.1
Hi Berube, you can probably just not worry about those edges, in most cases they're not doing any harm and so it's probably not going to be worth the time to try to get rid of them.
Right now there isn't any really easy way to remove those particular kind of edges, you would need to rebuild those particular faces in order to get rid of them.
I'm not sure if you're asking if you need to rebuild the entire model though? That's certainly not necessary, to get rid of the edge you show there you can do it locally by selecting the 2 faces to either side of it, delete those, select the bottom edge, run Extrude and snap the height to the top and then use Edit > Join to glue the new longer extruded surface back into the main object.
In the future I would like to make boolean union remove these kinds of edges and fuse 2 stacked extrusions into a single longer surface. But right now boolean union will only do that type of face merging on 2 planar faces that are coplanar or on 2 faces where the underlying surfaces of the face are coming from the same full surface. In order to remove the edge you show there, a new type of merging needs to be done where it would detect 2 stacked extrusions that could be represented by one extrusion.
8308.4 In reply to 8308.3
Once again, thanks for a prompt acute answer. Greatness.
I intuitively was doing what you recommend, though was using a Boolean as oppose to Join to glue the surface back together.
So thanks for the tip!
My main challenge is when I get edges like that, that are close to another edge I am trying to Filet per say. It seems the Filet can be blocked by the construction line as oppose to ignore it and glide right pass it.
Your proposed solution works perfectly fine. Thanks a lot!
Bests,
-Berube
8308.5 In reply to 8308.4
Hi Berube, you're welcome!
Yes, Join is a type of "lower level" operation than booleans. Join on surfaces will only try to glue open edges to other open edges, while the booleans are more focused on intersecting objects with each other and removing some material. It can work to use Boolean Union similar to Join, but it can also cause complications sometimes because of its focus on intersecting the objects and dealing with the intersection curves and discarding material as part of the process.
The booleans are kind of like a batch-mode operation where they cut up objects where they push through each other, then discard pieces depending on where they were contained in which particular volume, then automatically rejoin the results. You can do the same work in a manual way using Trim + manually picking which pieces to delete + Join. These manual steps can be useful if you want to do some localized repair to an object, but for your regular workflow it can save time using booleans since they combine multiple steps together.
There are some more details on how to do this type of work in the object repair tutorial here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
