faces disappearing and distorting
All  1-2  3-7
8300.3 In reply to 8300.1
Hi Sean, so faces looking like that usually means there's something wrong with the structure of the trim boundaries, something like edges or the uv part of edges criss crossing over each other or reversed in direction. These need to be repaired by separating out the broken face, and either building a new one and rejoining it, or doing an untrim and a retrim of it.
An object will read as solid just if it has no naked edges in it, meaning all edges are joined between 2 surfaces. It's unfortunately not very practical to do a more comprehensive analysis of an object because trying to find these types of boundary problems would involve a lot of calculation, and the object properties panel needs to be updated on every selection.
I'll see if I can tune those up for you. The process of doing low level repair operations like untrim and retrim is covered in this object repair tutorial if you want to know the details of how its done: http://moi3d.com/forum/index.php?webtag=MOI&msg=446.17
8300.4 In reply to 8300.1
Hi Sean, here's a repaired version of the smaller object. On this one the trimming boundaries were ok, the problem was that the underlying surface for that face was shifted some distance away from the trim boundaries. There's a bug in a geometry operation somewhere I think in filleting that does this rarely, I haven't been able to get a step-by-step example of how it happens which I'd need in order to get it fixed.
I'll see about the other piece next.
8300.5 In reply to 8300.1
Hi Sean, here's the other fixed up one attached. This one was a trimming boundary problem, somehow one of the edges in the model isn't there, probably another bug in some previous geometry operation but unfortunately I can't figure out where just by looking at the final result.
I fixed it by deleting the bad faces which were all around the missing edge, making new ones with the help of a line drawn in where the missing edge was at and then using Edit > Join to glue them back into a solid.
It's possible to repair an object with a couple of busted areas like this by using some "low level" surface operations like deleting faces or using Edit > Separate to detach them, then either doing an untrim/retrim of the damaged face or creating a new one and using Edit > Join to glue them back together. You don't need to remake the entire object this way.
Hope this helps! If you ever happen to catch this problem right when it happens please try to undo and save off the version of the object before it happens so I can try to repeat it over here. I'll need to "catch it in the act" in order to find out what was making the bad result and have a chance at fixing it up.
8300.6 In reply to 8300.4
Wow, thanks. I was just hoping for advice, I didn't think someone would fix the parts for me. If the missing face in the smaller part was caused by a random bug what about the distortion in the larger part? The bugs carry over into an stl file. I wonder what would happen if you tried to print them anyway.
Thanks again.
8300.7 In reply to 8300.6
Hi Sean, no problem. If you tried to print them it would probably be rejected by the printer software that takes in the .stl file and generates slices.
The problem in the larger one is also likely to be caused by a bug somewhere but a different one than the other one. I can't really tell for sure exactly what went wrong though just by looking at the end result unfortunately.
Show messages: All  1-2  3-7
