Hi Sandeep, sorry I wasn't able to give you better information the first try, so what you've run into here is the control point spacing of your curve affecting the flow.
If you draw a control point curve and have some control points close together and others far apart from each other, it will make the "parameterization" of the curve also be similarly bunched together and stretched out, and for a surfacing command that preserves the exact structure of the curve into the surface it will mean the UV parameterization of the surface will be the same.
If you rebuild the curve before doing the revolve, it solves it because the rebuilt curve has much more even parameterization.
