Working with scanned data
8272.1
Hello. I have a 3d scanner, Artec Eva, https://www.artec3d.com/3d-scanner/artec-eva and I need to get a solid from it's scanned data. How can i do it using Mol?
EDITED: 18 Jan 2017 by NASTYCAGE
8272.2 In reply to 8272.1
Way beyond my budget :-( The Eva alone at $14,000+++.
From the Artec website:
"•Artec Eva, Geomagic Design X and one year of Artec Studio Professional for $35,990"
8272.3 In reply to 8272.1
NastyCage,
It looks like you can export a .OBJ file from what I saw on the website. Depending on the polygon count of the file, you might be able to try Max's script:
http://moi.maxsm.net/item/18/category/1
Forum link:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.1
Michael T.
EDITED: 19 Jan 2017 by MICTU_UTCIM
8272.4 In reply to 8272.1
Can you indicate what you mean by a solid ...
- watertight triangulated solid (like STL) for 3d printing
or
- nurbs solid for cad or manufacturing use
8272.5 In reply to 8272.1
Hi NastyCage, a scanner like that will generate "point cloud" data, and MoI is not designed to work with processing that kind of data. So I would not recommend using MoI for that kind of task, you should look for software that is specifically focused on handling that.
It's a lot easier to generate triangulated mesh geometry from point clouds than it is to generate CAD solids. There is some software out there that can generate CAD surface data but it's pretty specialized and expensive. You could try some of the ones mentioned here: http://moi3d.com/forum/index.php?webtag=MOI&msg=1901.9
MoI is itself very focused on modeling shapes by drawing them and does not have any tools for working with scanned data.
8272.6
Hello,
Is the scan a one time project or will you be performing this operation regularly? I use M2S and Rhino for scan to CAD. Is the scan highly organic? If it's a one off and it's not a complex assembly I might be able to model it, assuming you can share the file.
