Custom Fillet - Corner issue
All  1  2-4
8269.2 In reply to 8269.1
Make a Sweep "2 Rails" ! ;)
EDITED: 17 Jan 2017 by PILOU
8269.3 In reply to 8269.1
Hi SanSingh, for the one rail sweep you show above, I'd probably use Edit > Separate on your path curve to break it into 3 separate individual curves and then do 3 separate sweeps instead of trying to do it all in one single sweep.
If that doesn't do what you're looking for, please post the 3DM model file with your path and profile curves in it so I can take a look at your actual geometry instead of only a screenshot.
8269.4
Good morning Pilou and Michael, thank you for your help.
Both methods worked perfectly!
Have a fantastic day! and thank you again!
SanSingh.
Show messages: All  1  2-4
