Script Select Object by Name
All  1  2-6
8259.2 In reply to 8259.1
Thanks MindSet, I'm glad you like MoI!
To select an object by name in a script, you'll need to loop through all objects looking for the one with the .name property that you want.
For example here's a shortcut key script that will select objects with a name of "objA":
<script>
script: var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name == 'objA' ) obj.selected = true; }
</script>
Also note that you can select an object by a typed in name without using script by pushing the tab key to put focus in the XYZ control and then type in the name and push enter. You can also use wildcard characters like typing in obj* will match anything starting with "obj".
8259.3 In reply to 8259.2
Hi Michael.
@ Also note that you can select an object by a typed in name without using script by pushing the tab key to put focus in the XYZ control and then type in the name and push enter. You can also use wildcard characters like typing in obj* will match anything starting with "obj".
Wow! I never knew that feature. Thanks a lot!!
See you.
8259.4
I found an example from Jun 2015
script: moi.geometryDatabase.selectNamed("ABC_NAME");
http://moi3d.com/forum/index.php?webtag=MOI&msg=7464.6
-- MindSet
8259.5 In reply to 8259.4
Hi Mindset, oh yeah I forgot that one was exposed to script. That's the same function that typing in the XYZ control and pushing enter uses, so you can also use wildcard matching with * or ? characters calling that one.
8259.6 In reply to 8259.5
Even better!
Thank you; you do such a great job and provide fantastic service!
-- MindSet
Show messages: All  1  2-6
