Circle to Square Loft - Why Won't This Fillet in Moi or Fusion 360 - Good Methods and Dos and Don'ts of CAD
 1-5  6-24
8255.6 In reply to 8255.4
I would also add to his quest to understand fillets, the "order" of particular fillets will allow success or box you in.
In this example, I believe the top fillets or blends attempting to achieve, marked in "red" , should come "AFTER" the attempted "green" blends and fillets.
But don't misconstrue. This is not something "different" than Michaels post..... Just added.
2 cents.
8255.7 In reply to 8255.6
Some programs can just do it!
Here's how I would achieve a result in MoI:
8255.8
Wow... this is incredible, you guys are absolutely amazing, thank you so much for taking the time to help me out, I didn't expect anything like this.
My problem is definitely solved... and in multiple different ways :)
@bemfarmer - thanks so much for the file, my brain would have fallen out of my head if I just saw that geometry and had to figure out how to make it. Tested it now, will definitely be exploring more of blend, seems like an incredible tool. Thank you!
@Michael Gibson - Thanks very much Michael, I get it now, reading the help file also makes more sense after seeing these, I see what I've not understood when reading about the fillet command. Thank you so much, I will definitely be considering the angle surfaces meet at now and most likely be considering a blend for this. Thank you!
@BurrMan - Thank you man, that's really awesome of you to take the time, I see your point about the order in which you fillet, I really was not considering that and thank you for the blend demo, I think that's what I'll be going for :) Could I please ask what the first application was that you were using? I couldn't see its name on the video.
Thanks again guys, I'm off to do some modeling now and hopefully end up with more than a square and circle after another 4 hours of trial and error :)
Will post some results... good or bad ;)
8255.9 In reply to 8255.8
The first program was SpaceClaim.
SpaceClaim is not a low price program! ;)
Try DesignSpark Mechanical who is the SpaceClaim's Kid but free! :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=6186.1
EDITED: 6 Jan 2017 by PILOU
8255.11
Thanks very much again everybody.
It appears, as it normally happens for me, that things are more complicated than they seem... I've attached the reference of what I'm trying to model and just a few quick fails I've gone through. I've been pulling my hair out over this for the last few hours again ( I have no hair...). The joint I'm trying to model has a very smooth transition from a capsule / cylinder to a rounded rectangle, but I just can't get that transition where they blend right.
I was hoping a blend might do it, I was also thinking of making a solid and boolean-ing a curve to trim for a smooth profile, but this doesn't give me the correct top view... I'm completely confused at this stage, it's my 3rd day trying to get this right :)
Off to work now, then will be back at it again after that small break :)
Thank you all again for the incredible help.
Thank you BurrMan and Pilou :)
8255.12 In reply to 8255.11
Hello Volen_ck;
I don't have acess to moi at the moment, but think about a profile extruded in the same direction the cylinder is. Draw a circle -> extrude! add a rectangle to the circle, trim to a closed curve sequence, join and extrude, Cut the result from the side view to the angle. Make the fillets Bool all together.
Or have a look here - for a different method for a similar problem:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7626.1
Have a nice day
Karsten
8255.13 In reply to 8255.11
Hi Volen, that's a pretty complex shape you're trying to build, it's not really a good candidate
for starting out and learning things because it has a high difficulty level with shapes melting into
each other. Often times forms that have that kind of melting quality can be easier to do in a
sub-d modeling program rather than in a CAD program, it's a much more difficult type of CAD
model. CAD modeling is strongest when most of the design is defined well by 2D profile curves
which usually isn't the case with melty type forms with complex transitions.
It looks like your main problem though is that you're trying to do too much of it all in one single form
right from the start, for example this piece here would probably need to be ignored to start with and
you'll build it later by doing a boolean with a narrower block:
8255.14 In reply to 8255.11
Something like a sequence more like this (see attached 3DM file also):
The last steps are putting in a large radius fillet here first:
Then a smaller radius fillet here:
So you've got to kind of build things in more stages and sub components than what you've been trying, and the smaller rounded areas
have to wait until the end until the larger fillets have been done first.
But these can also be some pretty difficult fillets for MoI to calculate as well, this has one of those "surfaces meet smoothly" type
situations in it where you can see the last fillet shrinks down to a point. When it's just a point at the very end of the fillet it can be
more feasible though. You may need some assistance from another CAD program with more robust fillets in it though for
this type of multiple level filleting.
Hope this helps give you more of the idea of how things are blocked out into separate pieces to start with though.
8255.15 In reply to 8255.14
In your example, in the third shape, i can put the larger fillet but can't put the smaller.
In the fourth shape , i can put the smaller fillet.
8255.16 In reply to 8255.15
@Finema
in the third shape Select the 2 half curves before to call the fillet! ;)
8255.17
i do that but failed
have you tried ?
EDITED: 6 Jan 2017 by FINEMA
8255.18 In reply to 8255.17
Hi Finema
Another way to solve your first problem (I think)
https://kdJonesgb.tinytake.com/sf/MTI0NjIyMl80NzE1Njkz
Best regards
Keith
8255.19 In reply to 8255.17
I did this with loft, mirror, and fillet.
8255.20 In reply to 8255.15
Hi Finema,
> Hi Michael,
You'll have to try a variety of different radius values, some radius values will work and others will be problematic. If you examine the very ends of the fillet when putting on the large one, you'll see some radius values leave a little wiggle in the shape at the very end, if that happens then the smaller fillets won't work although they may work on one side.
Like I mentioned above, these are some pretty difficult cases for filleting and you may need to use a different CAD program to put them in.
8255.21 In reply to 8255.20
Thanks Michael
it's clear now
8255.22
wow... thank you all so much, thank you for taking the time to explain this so thoroughly.
@Karsten - thank you very much, the thread was really useful, ended up making some faucets for practice :) Thank you!
@Michael Gibson - thanks so much Michael, this really cleared things up for me. I've gone through another few iterations, I haven't quite gotten it right yet, but being able to see the images you've posted, especially the step by step, has given me so many new ways to think about making geometry. Thank you so much!
@keith1961 - thank you so much for these... after seeing your example I couldn't believe I was ever struggling with this... you made it seem so simple :)
Thanks so much everybody, have been trying to model some more simple things to wrap my head around more tools, how and when to use them. I think I'll give this thing another try now.
8255.23 In reply to 8255.22
Hello Volen_ck,
attached some other proposals:-)
Have a nice day
Karsten
EDITED: 15 Jun 2017 by KMRQUS
8255.24
Thanks so much everybody. Just a quick update to show my model so far. It really sped up once the weird joint was figured out. It's still not accurate and I'm making tons of mistakes, but I did manage to build something. This is a WIP and will be working on more daily modeling to get more familiar with the process.
@Karsten - this looks awesome, thank you so much, will check the file out as soon as I get back home. Very helpful to have the step by step and the file, thank you for all the help and effort!
Show messages:  1-5  6-24
