Fonts in viewport with OSX
All  1-3  4
8254.4 In reply to 8254.3
Hi rickky, I'm glad that worked! You should normally have Arial already installed on your system though, it's been a part of the standard OS install for quite a long time now I think.
If you want you can also change the font that MoI uses by going to Options > General > "Edit .ini file" button and inside there find the [UI] section where you'll see:
[UI]
UIFontName=Arial
You can change that to a different font name if you want.
Show messages: All  1-3  4
