Fonts in viewport with OSX
All  1-2  3-4
8254.3 In reply to 8254.2
ok install Arial and it works
8254.4 In reply to 8254.3
Hi rickky, I'm glad that worked! You should normally have Arial already installed on your system though, it's been a part of the standard OS install for quite a long time now I think.
If you want you can also change the font that MoI uses by going to Options > General > "Edit .ini file" button and inside there find the [UI] section where you'll see:
[UI]
UIFontName=Arial
You can change that to a different font name if you want.
Show messages: All  1-2  3-4
