Hi
Been using Moi betas for ages now and not had any troubles. Started it up today and found that the selection highlighting and element picking has all gone crazy. Picking an object then moving the cursor over the surfaces will highlight the different faces correctly but not any of the edges. If an edge/loop does highlight it is miles away from the cursor and not the one trying to be selected. I saw there was a new beta aug-01 so downloaded and tried that, it is the same. Also tried older ones and they are the same. I've removed all moi beta versions and deleted the moi.ini in application data, to attempt a clean reinstall. It shows same problem.
I think this is a Moi rather than system/mouse issue because no other apps are showing any problems, including c4d and modo which both have similar preselection highlighting systems as Moi.
Any ideas?
