Boolean difference
 1-10  11-30  31-37
8249.11 In reply to 8249.9
Stefan, Thank you that worked perfectly.
Thank you for your help!
Gunter
8249.12 In reply to 8249.11
In fact i haven't understand what you want to do :)
can we show us the result ?
thanks
Another time a prove that send the 3dm file is crucial! :)
You're welcome Gunter,
glad it worked that way!
8249.15 In reply to 8249.1
Hi Gunter, so the problem there is that a line that is angled diagonally in 3D space does not have a well defined single extrusion direction.
The boolean will want to extrude the line into a plane and then use the plane to cut the object, but it needs to know what direction it should extrude it. When your line is on one of the world axis planes it will use that axis direction, that's why those other lines worked.
For your situation with a line at an angle not in a world plane like that, you will need to extrude the line into a plane yourself and then use the plane as the cutting object in the boolean. There is a "Set dir" option in the Extrude command that can be used for extruding in a specific direction.
Another way that might work more easily for making an angled cutting plane is drawing it using the Draw solid > Plane > 3 pts command.
8249.16 In reply to 8249.15
Thanks for clarifying. Making a plane worked well.
I'm now trying to make two recesses and have tried scaling and sweeping (Stefan's suggestion) but they don't seem to turn out right. I'm looking to create recesses only on the left and right faces, not the bottom of the object.
Thanks in advance!
Gunter
8249.17 In reply to 8249.16
You can make also a simple Sweep 2 Rails! ;)
EDITED: 4 Jan 2017 by PILOU
8249.18 In reply to 8249.17
Thanks Pilou, I tried that but I'm getting a strange anomaly at the corners.
Gunter
8249.19 In reply to 8249.18
hi
you can add an edge smaller between 2 form (see screen 1)
and do a Loft > Loose Style on the 3 3 edges (see srceen 2)
EDITED: 9 May 2020 by FINEMA
8249.20 In reply to 8249.19
Thank you Finema, that does work. I scaled the middle edge smaller but now the recess is all around the object rather than only the sides of the triangle which is where I would like them!
Gunter
8249.21 In reply to 8249.20
can you show us a screen shot ?
8249.22 In reply to 8249.20
Hi Gunter,
Can you please post the 3DM model file for this problem? It's very difficult to figure out what's going on just from a written description.
8249.23 In reply to 8249.20
This?
EDITED: 27 Feb 2020 by BURRMAN
8249.24
Hello,
Are you looking for something like this?
8249.25 In reply to 8249.22
Sure Michael, it's changed somewhat but here it is..
8249.26 In reply to 8249.24
Hi OSTexo,
This is exactly what I'm looking for! How do I get that?
Gunter
EDITED: 5 Jan 2017 by GUNTER511
8249.27 In reply to 8249.23
Exactly, thanks Burrman :)
Gunter
8249.28 In reply to 8249.25
when you use Loft > apply Loose Style
see the screenshot
8249.29 In reply to 8249.27
I just drew a cylinder along the wall of the little part and diffed it. I can make a video to show how i did that, but lets wait for Ostexo... his may be more elegant. He's a good designer.
8249.30
Hello Gunter,
I can do a video if you like, I should be able to get to it tomorrow if that is OK?
Thanks for the compliment BurrMan, I appreciate it.
Show messages:  1-10  11-30  31-37
