Creating a solid
All  1  2-4
Hi Gunter,
simply select the edges forming a face then run the "Network" command. Do that for every side.
After that join all faces and you should get a solid.
8246.3 In reply to 8246.1
Hi Gunter, for lofting and sweeping you'd do it like this:
Select these 2 and do a Loft:
Right click to finish the loft, then select these 2 and do another loft:
To do the sweep, select this as the profile curve, then run Sweep:
Then select these 2 as the rails for the sweep:
Now select the 3 surfaces that were just constructed and run Edit > Join to glue them together, then select that object and run Construct > Planar to cap off the bottom.
Also another way to do it would be to construct a full disc shape using Revolve, then build 2 slanted extrusions to use as cutting objects with boolean difference.
8246.4 In reply to 8246.3
Michael, as always, thank you so much for taking the time to explain all the steps in such detail :)
Cheers,
Gunter
Show messages: All  1  2-4
