Solid creation effecting fillet?
 1-14  15-25
8244.15 In reply to 8244.14
Well I tried, but as I posted previously, the fillet/fillet/chamfer don't create the same kind of surface arrangement you get with viacad, spaceclaim or even MoI (when it doesn't failed) on this particular example.
And I don't see any other option in Fusion to handle this result differently. Again I maybe miss something.
8244.16 In reply to 8244.13
Here you go PaQ...
Step Exported.
8244.17 In reply to 8244.15
Hey PaQ,
Regarding the Fusion example, yeah, that's a bummer result. The "Ruled Fillet" produces the intended result, but it's a FILLET!
The Chamfer option seems to be missing the ability to "Chamfer between surfaces", which is what the Fusion workflow needs, to achieve this....
Just so you don't lose hair over it.
8244.18 In reply to 8244.17
Hey Burr,
Thanks for letting me know about Fusion ! (and sor caring about my mental health ! :))
8244.19 In reply to 8244.15
No I speak about help of Fusion 360 for UpLoad a ".sab" file format!
SAT/SMT Files (*.sab, *.sat, *.smb, *.smt)
It can, but alas seems the .sab file from DesignSpark is exotic or too old...
Failed!
@PaQ and other fellows!
Bingo! :) (je ne lâche pas le morceau! :)
You must write -v 8 at the end of the line of the Windows Command Line!!!
(for have the command line in Windows 10 : Key Windows + R )
"C:\Program Files\DesignSpark\DesignSpark Mechanical 1.0\SabSatConverter.exe" -i "C:\Users\Desktop\MyObject.sab" -o "C:\Users\Desktop\MyObject.sat -v8"
C'est dans les vieilles marmites que l'on fait les meilleures soupes! :)
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/bingo.3dm here in 3dm as the .sat was now good! :)
EDITED: 4 Jan 2017 by PILOU
8244.21 In reply to 8244.20
Hey Frenchy,
How do you get the 3dm file from this post:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8244.1
Into designspark?
8244.22 In reply to 8244.21
I don't get this file: i just try to make the same fillet inside DesignSpark!
So seems it's now possible for obtain the file in Moi! :)
Sure a little tricky lines command!
I don't know if Vitaly Bulgarov has used DesignSpark or Moi or other ones!)
https://vitalybulgarov.com/about/
Astonishing collection! https://vitalybulgarov.com/3d-kitbash/black-phoenix-full-3d-kitbash-library-20-off-special-offer
Fot this poject seems it's Softimage XSI, ZBrush, Keyshot, Photoshop
http://vitalybulgarov.blogspot.fr/2013/03/black-phoenix-project.html
@Burrman
For import any file format Step in DesginSpark
Import the file format Step
Draw a sphere
Goto the top of the arborescence
Right Click / Lock
Magic : you can manipulate (and of course Hide/ Kill the sphere! :)
Just change the color as you want! :)
Onshape
Chamfer then Fillet
8244.25
Have you tried doing the chamfer first then the fillets
Show messages:  1-14  15-25
