Modelling advice needed
All  1-3  4-10
8228.4 In reply to 8228.3
Hi Tom, the curved shape adds quite a bit of complexity, is it possible to do a flat version and then produce the curved one by using Flow to deform it?
The method I was thinking of was to maybe focus on the arc end shape first by building something like this:
The idea there is to focus on the end shape by itself near the tip there, also you could construct this out a wide area and maybe trim off excess later. Then the center part gets surfaced separately with some space around it and a Construct > Blend is used to connect them together.
This is a lot easier to control with a flat shape though which is what I had thought you were doing...
Another possibility might be to make a shape that extended and dipped downwards past the outer surface and then got trimmed off something like this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4824.10
8228.5 In reply to 8228.4
Ok I have nt considered sweeping in this way, seems to be a
good approach. I´ll give it a try. Thank you !
8228.6
Hi Tom,
is this the type of result you want.
I networked the Bulge without the fillet and then tried various
fillets and blend solutions.
Hope it helps.
Barry
EDITED: 10 Mar 2023 by BARRY-H
8228.7 In reply to 8228.6
Hi Barry, thats coming pretty close. Do you still have the files to have
a closer look ?
8228.8
Hi Tom,
here is the file hope it helps.
Barry
8228.9 In reply to 8228.7
Here is a method of using blend. Adjusting the creation surfaces will control the bulge position.
8228.10
A big thank you to you MOIsters for your help will download the files and get inspired !
Show messages: All  1-3  4-10
