Converter for asg file ?
Hello
http://www-ui.is.s.u-tokyo.ac.jp/~takeo/java/smoothteddy/
Have you or can you make a converter for this 3D file format ".asg" in format "OBJ" ?
Unzipp files for have a ".asg" file !
Here 4 objects + program
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/smoothteddy.zip
Here 1 object
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/smoothteddy2.zip
EDITED: 12 Dec 2016 by PILOU
check this converter:
http://www.dadim.org/norbert/xsl/
and then load into Meshlab and save as .obj.
8215.3 In reply to 8215.2
If it's work that is fabulous!
(it's not for me! )
Alas yet tested!
asg2ob dead link
error java
Author contacted never answered!
Else find this one! Some similar! ;)
http://www.shapeshop3d.com/ (free) and export as obj!
8215.6
Hidden gems like this sometimes make me regret I'm on MacOS these days.
Michael, could there be any chance of a similar solid creation method? Something like a 2-Rail Sweep made even easier by freehand drawing of the components, combined with automatic Booleans.
— Metin
metinseven.com — 3D (print) models • animation • characters • icons • illustration • infographics • visualization
8215.7 In reply to 8215.6
Hi Metin,
don't regret that you are using macOS, because there is MagicalSketch available from the creators of Shade3D.
This is actually an old technique, which was many years ago available as plug-in for Shade3D. So, this is
nothing new what Pilou posted.
https://shade3d.jp/en/products/magicalsketch3d/overview.html
8215.8 In reply to 8215.7
@Stephan
Thx! Yes very similar! The only default : its' not free! :)
PS You said "as a Plugin" It can't work as stand alone ?
EDITED: 10 Dec 2016 by PILOU
8215.9 In reply to 8215.6
Hi Metin,
It doesn't seem too likely - it's something that's just generally better suited for generating triangle mesh geometry instead of NURBS geometry.
8215.10 In reply to 8215.8
MagicalSketch is a standalone tool, not a plug-in. It was however many years ago a plug-in for Shade.
8215.11 In reply to 8215.10
@ Stefan Thx for the info!
Guy who ask me about SmoothTeddy said that is the more easy and adapted program for school's kids
(he tryed a lot other) the only lack is a traditional operational export format for a 3D Printing !
So my first post! :)
Personally this program don't works for me (surely java problem) so I can't test it!
Little precision
if the file .asg is present just rename it in .zip
Unzip and you will obtain a file format xlm
EDITED: 13 Dec 2016 by PILOU
