How can I run MoI faster?
All  1-8  9-10
8207.9
Hi Woods
I also do jewellery design and manufacture also.
I find my laptop struggles as they are often only a dual core and the graphics cards are not the best.
My desktop system which is a quad core i7 on a SSD with a good graphics card is probably twice as fast.
A lot of filleted beads (like 1600 of them) will really slow you down as they take a lot of time for the graphics card to render.
A good script to use on a shortcut key is
script: /* Toggle mesh angle */ var newang, ang = moi.view.meshAngle; if ( ang == 5 ) newang = 10; else if ( ang == 10 ) newang = 25; else newang = 5; moi.view.meshAngle = newang; var sidepane = moi.ui.getUIPanel( 'moi://ui/SidePane.htm' ); var endsection = sidepane.document.getElementById('MiddleBody').nextSibling; if ( endsection.lastChild.id != 'angval' ) endsection.insertAdjacentHTML( 'beforeEnd', '' ); endsection.lastChild.innerText = newang;
This will toggle between a mesh angle of 5 10 and 25
It should help
Cheers shayne
8207.10 In reply to 8207.8
The "EDGES" will be making things really sluggish.
So instead of making 200 separate files to work on, use the naming conventions to separate objects and hide what your not working on.
For transforms, you can hide the edges of the selected objects also. This will allow you to use face snaps to move the object.
Show messages: All  1-8  9-10
