Convert a polyline, or polycurve, to a control point curve.
All  1-4  5-18
Thank you very much Brian! Now i don't have to use Shade3D for the conversion, cool!
8205.7 In reply to 8205.1
Your GosperCurve script is a very interest bit of kit.
The more aperiodic patterning the better IMHO.
And thank you for PolyCurveToCurveBeta script.
Does it produce a different result to DelCorners script,
in some circumstances? My cursory test produce
identical results.
-James
8205.8 In reply to 8205.7
Hi James,
They look the same...
Maybe I reinvented the wheel.
I'll have to check out _DelCorners.
8205.9 In reply to 8205.8
The result for a polyline appears to be the same.
Results for polycurves with at lease some non line segment parts is different...
I'll consider this script to be 99% "obsolete." The script only deals with start and end points, and so makes a different curve
than _DelCorners, for a polycurve with some or all non-line segment portions. It provided some practice in scripting.
The pre-existing _DelCorners script of Max Smirnov will change polylines to the same control point curve,
and also if the polycurve has some or all non-line segments, does some "rounding-off."
8205.11 In reply to 8205.10
Why not make your script into a node? It may require a little more work, but it would mean your time investment to date is not for nought, and you'll have an appreciative community of noders grateful of your efforts.
There is already a "ConvertCurveToPoly" node in ui/nodeeditor/nodes/SubD directory.
Just a thought.
-James
EDITED: 2 Dec 2016 by JFH
8205.12 In reply to 8205.11
James, thank you for the excellent suggestion.
(My work time may be limited by family health matters for 3-6+ months.)
8205.13 In reply to 8205.12
Brian,
I'm sorry to hear of your misfortune.
I wish all the best for you and yours.
-James
8205.14 In reply to 8205.12
Sorry to hear that Brian, best wishes from me as well.
8205.15 In reply to 8205.12
Hello Brian,
It makes me sad and also thoughtful to hear that. What is really important in life???
Take care of your loved ones.
I wish you and your family all the best.
-Karsten
8205.16 In reply to 8205.12
Hi Brian.
I am very sad to hear that!
...unfortunately in this lifetime it's impossible not to meet troubles and suffering...
I sincerely hope that you and your family will be better soon!!
Best wishes for all.
Thank you to everyone:-)
8205.18 In reply to 8205.17
All the best, Bem.....
Show messages: All  1-4  5-18
