problem with nodeeditor
8203.1
hi! i have a problem with run nodeeditor in Moi3D,after STARTUP nodeeditor script i see blank screen,but in IE10 INDEX.HTML(NODEEDITOR FOLDER) started after unblocking ActiveX,after insert to code index.html <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">.
Please, tell me who knows how to solve this problem. I'm still a beginner to work with MOI 3D.
THANK YOU IN ADVANCE...
8203.2 In reply to 8203.1
Hello serjilims,
please check your installation path - the nodeeditor folder/directory has to be placed in the ui - folder. The shortcut should have the same name like this folder. Your actual shortcut points to nodeeditor, so check if this fits to your directory.
Have a nice day and good luck!
Karsten
8203.3 In reply to 8203.2
HI Karsten (KMRQUS)!!!
THANK YOU VERY MUCH FOR YOUR ANSWER. THIS IS MY LOCATION NODEEDITOR.
SOMETHING IS WRONG???
8203.4 In reply to 8203.3
Put it inside the folder ui that you can see on your image! :)
8203.5 In reply to 8203.3
Oh!!!
I'm not careful !!! I put nodeeditor folder in c:\Program Files\MoI 3.0\ui\ and everything is working!!!
thank you very much!!! GREAT RESPECT to Karsten (KMRQUS) and Frenchy Pilou (PILOU)!!! :)
