Edges show through
8194.1
Why are edges of back facing surfaces showing through?
8194.2 In reply to 8194.1
Hi Mindset, that's a type of bleed through display artifact. Currently all edges are drawn the same way, and when edges are drawn they are pulled forward a little bit to avoid a worse type of artifact where they would tend to get partially hidden by the surfaces they are on. In the future I have some ideas on detecting back facing edges and not pulling those ones forward but that has to be done very carefully because the detection process will be extra work done during the display and any kind of extra work can have a negative impact on performance. One of the main goals for the display is to do things quickly.
Check out here for some more details:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4987.2
8194.3
Thank you Michael,
Is there something that can be added to the screen-shot to file script that might overcome the issue temporarily while the image is captured and saved?
You provide really outstanding service.
Thank you SO VERY MUCH!
-- Mindset
8194.4 In reply to 8194.3
Hi Mindset, sorry no there isn't anything that a script can do to control that.
Maybe try PDF export instead of a screenshot? Or the other thing you could do would be to export to a rendering program which will have more of a focus on generating a high quality image instead of a quickly generated one.
8194.5 In reply to 8194.4
You could just hide the edges....
