Batch modeling operations
All  1-12  13-16
8193.13 In reply to 8193.12
This really does what it should :)
How ever I have one more request. Can I have modified version that leaves only edges/curves?
Thank You again.
- J-P
8193.14 In reply to 8193.13
Hi J-P, no problem! For your modified version, insert the following code just below the object rotations inside the ProcessFile() function:
	// Duplicate edges of any remaining surfaces and delete the surface.
	var RemainingSurfaces = gd.getObjects().getFaces();
	for ( var i = 0; i < RemainingSurfaces.length; ++i )
		var Srf = RemainingSurfaces.item(i);
		var Edges = Srf.getEdges();
		for ( var j = 0; j < Edges.length; ++j )
			var Edge = Edges.item(j);
			var DupEdge = Edge.clone();
			gd.addObject( DupEdge );
		gd.removeObject( Srf.getParentBRep() );
8193.15 In reply to 8193.13
Hi jpvikholm.
If you want you could also add this little extra code, just below latest code that Michael sent you.
var joinFactory = moi.command.createFactory( 'join' );
joinFactory.setInput( 0, gd.getObjects().getCurves() );
joinFactory.commit();
This code simply join all resulting curves that can be joined.
Best,
8193.16 In reply to 8193.15
Excellent! All this makes things much easier. I had approximately 2500 profiles to convert and now it's all done. No headache, blurry vision or pain in the hands .... great!
It seems that I will be digging Moi3D little deeper from now on :)
Thank You Michael & Marco,
- J-P
Show messages: All  1-12  13-16
