How to quickly delete a hole?
All  1-2  3-5
8188.3
Hello Marco,
Well, shift-ctrl-select only works in isolated cases (in simple situations as you said). If you have an object with a lot of holes and so on it gets hard to select only the side faces of that single hole you want to delete. Nevertheless, I wasn't aware that you can delete "open" edges by selecting all edges of an object and then pressing delete. I'd assumed it would affect the rest of the edges. So, quite clever and good to know! :-)
Thank you
8188.4 In reply to 8188.3
Hi 3image for an object with many holes, I'd recommend saving a separate version of it before you put in so many of them, that way you can just go back to that previous version if you don't want the holes anymore.
For the case you show in your first image though, the window selection will do it quite quickly.
8188.5
>> In that way all the trimmed surfaces go back to being untrimmed and the hole disappears!
Been using Moi since 2011 and I did not know that! :o :D
Sebastian
Show messages: All  1-2  3-5
