Simple Boolean Diff Issue
All  1-7  8-13
8186.8 In reply to 8186.7
The solid is difficult to work with, but after about 8 repeated tries:
There appears to be actual bevel thickness on the delta side of the cab solid.
There are two copies of the cab. One has a skinny delta shape, which will not quite match up with the other cab.
There would be a narrow sliver of a gap, between the "wrong" surfaces, or overlap, near or at the delta shape.
First of all, color the box magenta and hide it.
Secondly, Separate the solid cab.
Pick the "inside" surfaces, one by one, and color them say red. Join the red surfaces.
If more than one red joined surface occurs, some of the surfaces are the wrong ones, with a narrow gap or overlap, so swap a surface at or by the delta,
until the red surfaces are "continuous", without gap or overlap, and will join to one joined surface.
Hide the red surfaces.
Color the remaining "outside" surface say cyan. It should Join to one surface, if the red one joined to a different one joined surface.
Now the magenta box will trim the red cab.
The red cab will Offset Shell just fine, either outwards, or Flip inwards.
EDITED: 19 Nov 2016 by BEMFARMER
It's not more simple to make a simple scale *100 for all objects ?
Make the Boolean operation
Then Scale * 0.01
EDITED: 19 Nov 2016 by PILOU
8186.10 In reply to 8186.9
> Then Scale * 0.01
That's probably not going to help for this case - on one side of the object there doesn't seem to be any thickness at all, the inside and outside surfaces on one side are directly overlapping on top of each other. That kind of self-intersecting object will confuse the booleans.
@ Oliver - does Brian's file above solve it for you?
8186.11
Thanks again, Brian, Pilou and Michael !
Unfortunately, Shell didn't work for me, from a clean joined surface
I get a messed up joined surface, not a clean solid.
Basically, joined surface would be fine, but as you see
3D Coat, the program I texture in, obviously has Normal
problems after import.
Oliver
o5m6.de
Beware of the hun coming out of the sun ;-)
8186.12 In reply to 8186.11
Hi Oliver - shell in MoI for thickening a surface can only really work on a single surface or one that is all smooth. Areas that have several surfaces meeting at an angle to on another are much more difficult because the offsets become separated and need to be extended out in order to meet up with each other.
If you make your object a closed solid rather than a joined surface by capping it off, shell might have a better chance, but what I'd probably do would be to manually make the inner core by doing a curve offset of the top and bottom pieces and then lofting between those, then do a boolean to cut it out, see attached model.
8186.13
Ty, Michael, that did the trick.
Oliver
o5m6.de
Show messages: All  1-7  8-13
