import sketchup
8181.1
Hi ..
I need to import a sketchup model. Is this possible?
MoI exports to Sketchup directly and easily but not the other way around?
thanks,
eric
Of course yes! :)
Export an OBJ format if you have Sketchup Pro
if you have Sketchup Make use the Export OBJ by Tig or by Thomthom QuadFace tools
http://sketchucation.com/pluginstore?pln=OBJexporter
http://sketchucation.com/pluginstore?pln=QuadFaceTools
https://bitbucket.org/thomthom/quadface-tools/wiki/Feature%20-%20OBJ%20Export
and use _importObj by Max Smirnov for transform your OBJ format file inside Moi! ;)
So you can use _SubDivBeta9 by Max Smirnov on an SKP File! :)
French Sites : http://moiscript.weebly.com/_importobj.html
http://sketchupsubd.weebly.com/
After _SubdivBeta9 on the Box (SUbdivbeta9 don't works with any Polygonal volumes! )
EDITED: 14 Nov 2016 by PILOU
8181.3 In reply to 8181.1
Hi eric, SketchUp models are made up of polygons only so that's why there is no .skp format import for MoI and only an exporter.
Try using Rhino though, I think it has an importer with an option to convert large planes with holes in it into trimmed surfaces.
8181.4 In reply to 8181.3
Thanks Michael and Pilou ..
Michael .. yes, importing into Rhino as trimmed surfaces worked well.
cheers,
eric
