Info about Intersect script
All  1  2-7
8179.2 In reply to 8179.1
Hi MajorGrubert.
But...what kind of details ?
Maybe this ?
http://take.ms/U2l3uV
You can find it at "<Moi folder>/docs/moi_command_reference.htm#intersect"
best,
8179.3
Hi mkdm,
Already found, but thanks anyway.
@Michael (if you are checking this post):
Its possible this script place the intersected curves in a new/own layer called 'intersections' or something, or even better, make new solids of the intercetions (in a complex model is easier to check/find solids than curves).
Carlos
8179.4 In reply to 8179.3
Sounds like MoI command Boolean Isect?
8179.5
Cool, i'll check that. Thanks Brian.
8179.6 In reply to 8179.3
Hi Carlos,
Well, the results of the Construct > Curve > Intersect command are selected when the command finishes, so you can set up a layer called 'intersections' before you run it, and then assign the selected new curves to that right afterward.
For making solids maybe boolean intersection as mentioned above might be better.
8179.7
Ok. Anyway, when i was triailing Fusion 360 i found a command called Interference and it work pretty well: It found the interference, create own layer and make new solids from interferencies.
When comparing both apps (in the same step of my workflow) it was much easier to spot interferencies (in complex models) than Moi's outline curves, so i try to mimic it on Moi.
Carlos
Show messages: All  1  2-7
