Hi Carlos,
> Its possible this script place the intersected curves in a new/own layer called 'intersections'
> or something, or even better, make new solids of the intercetions (in a complex model is
> easier to check/find solids than curves).
Well, the results of the Construct > Curve > Intersect command are selected when the command finishes, so you can set up a layer called 'intersections' before you run it, and then assign the selected new curves to that right afterward.
For making solids maybe boolean intersection as mentioned above might be better.
