Placing spheres on knots/vertices
 1-7  8-27  28-39
8166.28 In reply to 8166.27
Hello Pilou,
I don't have any plans to make a fork of the elephant - everything I made is an addition to Maxs untouched core development (I put it all together, because I think it is easier to handle for other users). And if Max change something important - I have to change the nodes - so I did it in the past.
I try also to understand Max philosophy and make it compatible to the planned workflow. It is possible that most of the nodes and solutions are someday obsolete - so it was in the past, but some ideas of me and others may help to get a better tool. I don't know if I can handle all that stuff - every help, every idea is welcome. I don't know why I try to create nodes - maybe just for fun, maybe it is exciting to see what is possible and what others try to do. I try to understand this tool and check the possibilities - If I would need a finished tool, I would buy grasshopper.
Everything is limited in general and my programming skill in special - my nodes don't have the quality or performance of Max ones, but you have always the freedom to play with them, or ignore them, or improve them, or make proposals for better solutions, create something with them, ....
Have a nice weekend
Karsten
p.s.:I switched back to this thread, because I don't want to confuse other users with my posts.
8166.29 In reply to 8166.26
Hello Marco,
you can use the cat50x50.csv from libelle. Create the node and choose the file - thats it. Now you have a pointarray at the output. If you have a look in the Info you will understand how it works;-)
The node works with absolute path-names, so it would only confuse others, that only have a quick look in the nodefile. It's only a draft that has to be improved and I'm not an expert of file handling and parsing :-( If there are comment lines in the CSV-File you can choose a start phrase and an end phrase for start and end of evaluation the columns. You can switch to numarray to evaluate only one column. You choose the column by the number in one of the fields (starting with 0 for the first column) "-1" means no evaluation for pointarrays a default value will be set.
Have a nice weekend
Karsten
@ Karsten
Thx for the Infos!
So if I good understand now there is "2 big" one! :)
nodeeditor.v.0.85 (by Max)
nodeeditor.v.0.85mod5 (By mkdm & others ;)
Am I right ?
8166.31 In reply to 8166.30
You're right!
See you.
8166.32 In reply to 8166.31
Does it possible to have a list of new nodes different (and their functions) than the native Elephant native ?
8166.33 In reply to 8166.32
Hello Pilou,
here is a quick and dirty overview of all nodes - not complete, because for Marcos nodes, I have to take a second look - I know only the standard functionality.
Have a nice day
Karsten
EDITED: 6 Mar 2019 by KMRQUS
8166.34 In reply to 8166.33
Hi karsten.
I'm confident to find some free time tonight to update your xls with the infos of my nodes.
Thanks.
8166.35 In reply to 8166.34
Hello Marco,
that would be fine, but let us switch back to another thread - here is a different focus!
Have a nice and productive evening
Karsten;-)
8166.36 In reply to 8166.35
Hi Karsten,
> "...let us switch back to another thread..."
I totally agree with you.
Let me know.
Best,
8166.37 In reply to 8166.35
Hi Karsten.
I have updated your "nodes_V0.85_mod4.xls" and created the new file "nodes_V0.85_mod5.xls"
containing an updated version of the infos of all my nodes (column Authors : Marco).
I have also slightly modified the layout of the excel, in order to get more columns and a better reading.
If you don't like this layout, you can freely change it, as long as you don't remove the additional columns.
Let me know when you have created the new thread for this documentation, so I can upload this new excel file.
Best,
8166.38 In reply to 8166.37
Good morning Marco,
Nodebundle for playing with nodes, here we have everything in one place or create a new one, maybe Brian has also docs for the core.
@Brian: What was/is your decision for the document format?
A nice day to all
Karsten
8166.39 In reply to 8166.38
Hi Karsten,
I have no particular expertise in software documentation, but did do some preliminary documentation for NodeEditor in Word / PDF.
Link: https://en.wikipedia.org/wiki/Software_documentation
EDITED: 16 Nov 2016 by BEMFARMER
Show messages:  1-7  8-27  28-39
