Moi and 3DCoat
8145.1
Currently playing with texturing MOI-created objs in 3D Coat.
Exported from MOI with "N-gons" and imported in 3D Coat as is.
Everything was fine, except for the upper faces of the Solids
(white on screenshot) that remained unaccessible for texturing.
Any idea ?
Oliver
o5m6.de
Beware of the hun coming out of the sun ;-)
8145.2 In reply to 8145.1
Hi Olivier,
It's not a good idea to export with NGon options when exporting to software like ZBrush or 3DCoat.
I use 3D-Coat for texturing/painting/retopo and often the best export settings in Moi are :
- Quad+Tris
- Weld vertices
- Angle (it depends on the topology of the model that you are exporting, but in general between 3 and 10)
- Divide larger than : THIS IS THE CRUCIAL POINT. It depends on the scale of your model but in general I use values between 1 and 10
- Divide : ALL
With this settings all should works fine in 3D-Coat.
Here's a screen cap http://take.ms/hTRad
Best,
8145.3
In addition to Marco's solid advice, you can access the Moi.ini configuration file via the Moi Preferences. In that file make sure the CentroidTriangulation option is set to "y" (yes). This can also make a difference, at least in ZBrush it does.
— Metin
metinseven.com — 3D (print) models • animation • characters • icons • illustration • infographics • visualization
8145.4
Thanks a lot, Marco and Metin.
Following your advices I got some 2M polygons on the export
and after importing into 3DCoat the "white spots" had decreased.
Now, 3D Coat crahed several times in the texture painting process, though.
So, no chance to further increasing polygons in Moi.
Oliver
o5m6.de
Size: 184.3 KB, Downloaded: 110 times, Dimensions: 1200x650px
8145.5 In reply to 8145.4
Hi Oliver,
> "...and after importing into 3DCoat the "white spots" had decreased. Now, 3D Coat crahed several times ..."
Hmm....I think there's something wrong with your exporting/importing from Moi to 3D-Coat.
For example "white spots" shouldn't be at all.
How much free RAM you got ?
WIch settings are you using in 3D-Coat for "per-pixel" painting import ?
Could you post one of the 3dm file that is going wrong ?
P.S. A very good idea could be to query 3D-Coat forum. It's a great place with a lot of support.
Best,
8145.6 In reply to 8145.4
Hello Oliver,
Thanks a lot for your appreciation regarding little suggestions I gave you.
Unfortunately right now I'm very, very busy at work and I can't provide a decent help.
But I strongly suggest you to start a new topic in 3D-Coat forum and, if you can, to upload there your obj files.
3D-Coat forum provides a great support from Pilgway's developers and from many advanced users.
It's not necessary to upload ultra-high tessellated versions of your objs.
There are too many variables that come into play when it comes to importing for Per-Pixel-Painting in 3D-Coat,
and the experience of advanced users could solve your problem.
Here's the forum url : http://3dcoat.com/forum/index.php?/forum/4-3d-coat/
Have a nice day and best wishes for your job.
