Limondaine lemonade bottle packshot
All  1-7  8-14
8140.9
You must be the hero of a lot of French 3D artists, Frenchy, spending so much time on translating MoI, ZBrush and SketchUp data and info. Very generous of you.
Hi Metin,
yes i am the same Stefan, you advised. :-) ZbrushCore does not have ZRemesher for example, but it is no problem for me, since i will save money for the full version and purchase it next year, so your explanations in your other MoI thread are very helpful for me and i save it for later reference. I will however try Centroid setting with Dynamesh. I visit now ZBRushCentral very often and i'm amazed how so much superb artworks can be created with ZBrush, simply amazing. Wish i had not bought so much other software in the past and spend the money instead for ZBrush.... ;-)
Best regards
8140.11
Hi Stefan,
My pleasure.
And I totally understand what you mean — when it comes to organic modeling there's nothing like ZBrush. But for fast, smooth and accurate hard-surface modeling there's nothing like MoI. Combine the two, add a great renderer (like Keyshot for ZBrush, or Blender's Cycles), and you can create anything you want.
Investing in ZBrushCore is a wise first step. If you find out that you're hooked, the full ZBrush is definitely worth every penny, like MoI.
All the best,
Metin
I completely agree Metin, and what i also like about ZBrush and ZBrushCore is that they offer an affordable Keyshot solution.
Best regards
EDITED: 22 Oct 2016 by STEFAN
8140.13
Absolutely. I would not have owned Keyshot Pro if it wasn't for the ZBrush option.
— Metin
metinseven.com — 3D (print) models • animation • characters • icons • illustration • infographics • visualization
8140.14
For exporting to Zbrush, I found the best export settings are when you divide "larger then" on all surfaces at a reasonable setting to prevent triangulation issues, and to have Quads + triangles output. This will prevent long and thin triangles and keep them small so that Zremesher has even normal data to create a good surface.
Show messages: All  1-7  8-14
