Limondaine lemonade bottle packshot
All  1-3  4-14
Hi Metin,
very nice work and presentation!
Since you mention that you use ZBrush for detailing, i would like to ask you what are the best export settings from MoI when using ZBrush to finalize a model. I ask, because i just have bought the little ZBrushCore and thought also to combine MoI and ZBrushCore usage. I know it does not have all the big features like ZBrush, but maybe you have a tip or two handy if one should use better Dynamesh or subdividing first after import etc.)
Best regards
8140.5 In reply to 8140.1
Great work Metin!
8140.6 In reply to 8140.1
Hi Metin,
It's really a very effective and communicative presentation, IMHO above all for its warm environmental lighting and the viewpoint,
slightly from the bottom up.
Best,
8140.7
Thanks a lot guys, very much appreciated!
Stefan, do you happen to be the same Stefan I advised about importing vertex colors at the ZBrush Central forum? :)
You can read all about my MoI ➔ Zbrush export settings in this discussion:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=8109.1
Additionally, I assign Styles to surfaces in MoI, and import in ZBrush using the option to import Obj materials as polygroups. Then I use those polygroups as ZRemesher guides by activating the KeepGroups option. I'll add this to the other discussion as well.
But I don't know if all the mentioned options are available in ZBrushCore. You'll have to find that out.
Have a great weekend y'all,
— Metin
metinseven.com — 3D (print) models • animation • characters • icons • illustration • infographics • visualization
8140.9
You must be the hero of a lot of French 3D artists, Frenchy, spending so much time on translating MoI, ZBrush and SketchUp data and info. Very generous of you.
Hi Metin,
yes i am the same Stefan, you advised. :-) ZbrushCore does not have ZRemesher for example, but it is no problem for me, since i will save money for the full version and purchase it next year, so your explanations in your other MoI thread are very helpful for me and i save it for later reference. I will however try Centroid setting with Dynamesh. I visit now ZBRushCentral very often and i'm amazed how so much superb artworks can be created with ZBrush, simply amazing. Wish i had not bought so much other software in the past and spend the money instead for ZBrush.... ;-)
Best regards
8140.11
Hi Stefan,
My pleasure.
And I totally understand what you mean — when it comes to organic modeling there's nothing like ZBrush. But for fast, smooth and accurate hard-surface modeling there's nothing like MoI. Combine the two, add a great renderer (like Keyshot for ZBrush, or Blender's Cycles), and you can create anything you want.
Investing in ZBrushCore is a wise first step. If you find out that you're hooked, the full ZBrush is definitely worth every penny, like MoI.
All the best,
Metin
I completely agree Metin, and what i also like about ZBrush and ZBrushCore is that they offer an affordable Keyshot solution.
Best regards
EDITED: 22 Oct 2016 by STEFAN
8140.13
Absolutely. I would not have owned Keyshot Pro if it wasn't for the ZBrush option.
— Metin
8140.14
For exporting to Zbrush, I found the best export settings are when you divide "larger then" on all surfaces at a reasonable setting to prevent triangulation issues, and to have Quads + triangles output. This will prevent long and thin triangles and keep them small so that Zremesher has even normal data to create a good surface.
Show messages: All  1-3  4-14
