Thank you for the pep talk :)
That "doodle" it's just a very coarse one, created in 15 min regardless the correct alignment of the seem edges (I mean "correct" in relation to boolean operations),
and without advanced filleting/blending.
Anyway....I guess that with the upcoming "instances support" feature of the next V4, it would be easy to create an assembly
for a "greenhouse" of that plant.
I would like to ask your advice :
Usually, as a final stage of my modelling process, I save two versions of the the model.
One, the original, as is, in the case I want to continue the modelling, and the second one on which I run these commands :
1) shrinktrimmedsrf
2) merge (edges)
I do this way for cleanup purposes, especially after many boolean/trimming operations.
Is this a correct technique ?
Best,
