Share your MoI keyboard shortcuts
 1-5  …  26-45  46-65  66-72
8123.66 In reply to 8123.65
Scale, Scale1D, Scale2D ;)
http://moi3d.com/4.0/docs/moi_command_reference11.htm#shortcutkeys
But for that you want exactly no need shortcut it's direct! :)
EDITED: 14 Apr 2023 by PILOU
8123.67 In reply to 8123.66
& thanks for your feedback ;-) ... However, I am not sure we are thinking about the same - at least when I insert e.g. Shift+Q=Scale(1D, or 2D) into the Shortcut keys list something else than what I was intending seems to happen ..
Just to clarify: In the "properties panel" description in this link: http://moi3d.com/4.0/docs/moi_command_reference11.htm#shortcutkeys (approximately half way down the page) I would like #4, i.e. the "Edit Size" dialog to open up so that the "cursor" is immediately placed e.g. in the x-axis size dialog box. I hope this make sense ... ? BTW I use the MOI3D V3 version - maybe that makes a difference?
Cheers,
Jesper
8123.68 In reply to 8123.67
Hi Jesper, see here for a script that you can put on a shortcut key for opening up the edit size menu:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10769.2
8123.69 In reply to 8123.68
& thanks for your prompt & helpful reply ;-)
However, when I try your script I get an error message saying that " Typeerror: Result of expression 'moi.ui.findElement' [undefined] is not a function. " ... I have attached a screendump of what the moi.ini looks like an the error message. Maybe I need to change something somewhere to make it work ... ?
Cheers, Jesper
Size: 358.7 KB, Downloaded: 32 times, Dimensions: 2560x1440px
8123.70 In reply to 8123.69
Hi Jesper,
The script uses some infrastructure that was added in MoI version 4, but you're using MoI version 3, so that's the problem.
Try this instead, it should work ok in v3:
script: /* Show edit size menu */ moi.ui.showMenu( 'EditSizeMenu.htm', moi.ui.sidePane.PropSizeContainer, 0, 0 );
8123.71
Thanks again for helping out with this - I have copied the script to my .ini list and it works fine! ... Much appreciated ;-)
Jesper
8123.72
This topic saved my life..
Now I works too fast, thanks to all!
Show messages:  1-5  6-25  26-45  46-65  66-72
