Newbie has problem with soliding
All  1  2-3
812.2 In reply to 812.1
Hi Thomas - Planar won't work in this case because the top edges are not flat. Looking at them from the front view, they have a curve to them:
But you can use a different method to create a solid there - select the 2 top edges and then run Construct / Loft to build a surface between them. Then select that surface and the rest and use Edit/Join to make it into a solid.
However, I don't think that you're going to have any luck shelling this in MoI - MoI's sheller is pretty sensitive. There are 2 situations here that it won't like - the tight bend near one end, and also the way the surface collapses down to one flattened edge at the bottom.
Shell won't be able to handle this situation - for this one you'll have to manually build the inside or outside surface.
Check out here: http://moi3d.com/forum/index.php?webtag=MOI&msg=784.4 for a recent discussion on a similar model.
812.3 In reply to 812.2
Hi Michael
thanks for your very quick answer
so i made the surface with loft and got a solid.
Fine
After that I copied it, scaled the copy with 0.9875 and set it in the 1. form.
I tried to make a difference (after selecting both) from these two forms but i failed.
Why??
Update
Now I Know Why: I was too stupid
ok works fine
Thanx again Michael
what a little rest can do....
EDITED: 30 Jul 2007 by THOMAS
Show messages: All  1  2-3
