How to "assemble" a model from part files
All  1-3  4-8
8113.4
The technique I have been using which is working well.
I create a wireframe skeleton which I then create by parts around with same portions of the wireframe which I then use orient to put into position. AS moi opens instantly I have 2 moi windows open one with my assembly bound to the wireframe and then I copy and paste the part or wireframe working in the empty moi window viewing extents only. I then copy the part and it skeleton back in.
I have used Solidworks for many years and I have been using MOI for assemblies for some time and must say I am completing the job in same or less time - less files to manage and less mouse maneuvers. Same output as most manufacturing facilities accept STEP files the output is the same. Workflow is great. I still import my final 3dm files into SOLIDWORKS for its drawing sheets if required thats a hard one to beat.
I present my MOI files with SIMLABS 3d pdf and the clients love it WYSIWYG presentation with just a few clicks.
Here is 3d PDF created in MOI exported to SIMLABS - even the sheetmetal part is created in MOI once you know the steps of SHEETMETAL protocol radius's and allowances - I imported the part into SOLIDWORKS sheetmetal and unfolds perfectly.
Here is 3d PDF from MOI you need ACROBAT VIEWER to view correctly.
cheers
EDITED: 23 Dec 2023 by ALEXPOLO
8113.5 In reply to 8113.4
hi Alex
Using copy and paste on Skeleton with 2 screens is a good idea.
Simple and efficient !
Thanks for sharing
Chri
8113.6 In reply to 8113.4
Hi AlexPolo,
I wish to thank you for your very interesting post!
> I create a wireframe skeleton which I then create by...
It's a very smart technique, similar to that used by Chipp Walters for his Kitbash libray,
but here in a bigger scale.
> I have used Solidworks for many years...
There is no denying that working with high-end Cad/Cam can give a wider point of view and a smarter mind.
Thanks a lot also for the 3d pdf!
Nice day,
8113.7 In reply to 8113.4
Hi Alex, definitely a great technique to build around common frames of reference like that, thanks for sharing!
8113.8 In reply to 8113.7
Taking MOI forward into assembly use for manufacture as a serious toolset it would be highly handy when exporting that the selected object name becomes the preselected filename I am doing this manually and works well but when managing lots of parts with similar names a typo could mean wrong order qtys for that part.
Just a wish item for V4 moi.
PS I am using the cutlist script to prepare BOM that also works 90% but if that tool was polished a little further MOI is a serious contender in assembly based manufacture.
Show messages: All  1-3  4-8
