Setting parallel or perspective as default view
8112.1
I noticed that each time I restart MoI, the Parallel option of the 3D view has reset to Perspective. I'm using the Mac version of MoI.
For now I'm using this inline script as a way around it:
script: /* Toggle between Parallel and Perspective view */ var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); vp.projection = (vp.projection == 'Perspective' ? 'Parallel': 'Perspective');
— Metin
metinseven.com — 3D (print) models • animation • characters • icons • illustration • infographics • visualization
EDITED: 29 Sep 2016 by METINSEVEN
8112.2 In reply to 8112.1
Hi Metin, you can set the default by saving a 3DM file with the projection set how you want it, then set that 3DM file as the template file under Options > General > "Template file".
Styles will also be read from the template file as well at startup and when doing File > New.
8112.3
Ah, great, thanks for your swift reply Michael!
— Metin
