Crash
 1-18  19-23
8111.19
I have no key, that is trial for test to my school work
8111.20 In reply to 8111.19
Hi freename, well the main way that what you describe can happen is from running a cracked version. I don't know of any way that it could happen with the trial version. So make sure you're getting the real trial version from http://moi3d.com/download.htm and not from somewhere else.
There is an educational discount version which you can order from Studica here: http://studica.com/moi3d
8111.21 In reply to 8111.20
Hmm..right is that I didn't download it form regular web. I tried find some easy way how to modelling assigned task without any software modelling knowledges. I found some webpage there were a few softwares with links..supposedly free beeng said. It could be it. I will try use file from your web.
8111.22
Hello Michael,
I tested correct tiral version from your web, but without success. Unfortunatelly some error happend during installation and application can not run.
https://postimg.org/image/q8c4gdfn9/
Probabyl tax from installing application from some not serious web.
Anyway thank you for your time and help.
Best regards.
8111.23 In reply to 8111.22
Hi freename, that's probably your anti-virus interfering with the installation. Are you possibly running ESET? That particular anti-virus checker mistakenly identifies moi_lib.dll as containing a virus because it categorizes anything wrapped with the WinLicense anti-hacking mechanism as a virus. There should be some way you can turn it off temporarily or tell it to make an exception for the MoI trial.
Also the alternate "no save" trial version is not wrapped with WinLicense and so probably won't have the same installation problem.
Show messages:  1-18  19-23
