Moi 3.1 and macOS Sierra
8101.1
It works so far...(even faster??) but again its no more possible to open a "New Window"... same as with Yosemite....
8101.2 In reply to 8101.1
Hi r2d3, I'm glad that it is working and not getting any worse!
The "New window" works fine for me on El Capitain, so I'm not sure what the problem there is.
MoI version 4 with a native Mac build will be a lot less complex than the current version and so should probably be a lot more resilient to OS changes I hope.
8101.3
Hi r2d3, i can verify the issue with New Window in Sierra, but its relatively easy to fix.
- Right click on Moi V3.1.app and select Show Package Contents.
- Navigate to folder: Contents / Resources / WineskinMenuScripts
In the WineskinMenuScripts folder you'll see a file called NewWindow.app which looks like:
Right click on that and choose open, then open with Automator.
Inside Automator choose save, overwriting the original file and then quit Automator.
Thats it! New window should work fine after that.
8101.4 In reply to 8101.3
Hi Dinos, thanks for figuring that out with the solution!
Do older Automator apps sometimes not work on new OS releases?
8101.5
Dear Michael,
I see one big bug, everyday ...when you are on a dual screen if i put moi in the second screen I can't save... the window will not appear ...
Voila, have a good day
Nicolas
8101.6 In reply to 8101.5
Hi Nicolas, Apple made some big changes in how multi monitors work, and the libraries that the MoI Mac version currently uses are not compatible with those changes yet.
If you change the OS setting to go back to the previous multiple monitor behavior that may avoid the problem.
The setting is under System Preferences > Mission Control - uncheck "Displays have separate Spaces" there.
You will then need to reboot your system in order for this change to take effect.
Does it behave any better after that?
The next version of MoI should not have this problem anymore.
8101.7 In reply to 8101.3
Wow it works!
Thank you very much for sharing!
Ralf
8101.8 In reply to 8101.4
Hi Michael, this is the first time I've noticed this behavior.
I got the same issue (and the same icon) with some normal Mac apps that used to work perfectly until Sierra so obviously something is changed.
In one particular case i traced the issue to: "Objective-C garbage collection is no longer supported" but this should have nothing to do with Automaton..
Dinos
8101.9 In reply to 8101.8
Hi Dinos, well I'm glad you found a solution that works!
Probably my biggest gripe with Apple is that they seem to hardly focus much attention on backwards compatibility.
I am certainly hoping that MoI v4 will be more resilient in this area though since it will not have so many layers of apps in it.
8101.10
I just tried this tip and the one about a setting in Mission Control, and neither had any effect on the missing Title Bar with MacOS Sierra.
I can neither move nor minimize a window in MOI 3.1
Could we please have a bug fix before the eventual MOI 4?
8101.11 In reply to 8101.10
Hi Rick, did you restart your machine after changing the "Displays have separate spaces" setting?
Unfortunately there is not any fix available for it yet in the library that MoI 3.1 uses.
8101.12 In reply to 8101.10
Hi Rick, another thing you can try to see if it helps is to install the latest XQuartz from here: https://www.xquartz.org/ and then change the setting in MoI for it to use the system installed XQuartz rather than the bundled one as described here: http://moi3d.com/forum/index.php?webtag=MOI&msg=6967.4
8101.13
I did restart the system after trying the first two tweaks.
The last one - of installing newer Quartz, appears to have done the job - I now get a title bar with window controls that work, but it gets launched from a bash window that stays on-screen.
Oh well, at least it's a workaround that restores the function - Thanks.
8101.14
Unfortunately, while it solves one oissue, ot creates another. Because it is running from a XQuartz parent, the Edit menu does not apply to MOI - you cannot copy/paste objects in MOI.
Now the question is how do I get Editing functions back?
8101.15 In reply to 8101.14
Hi Rick, what about Cmd+C for copy and Cmd+V for paste, or MoI has Copy/Paste buttons on the Edit section of the side pane.
8101.16
Right you are - the shortcuts of Cmd+C and Cmd+V do work, and I had completely missed the Copy/Paste icons in the sidebar.
Thanks. Looking forward to v4.
