Rocket 3F polygon modeling with bridge to MoI and 3D Coat
 1-7  8-27  28-47  48-67  68-87  …  108-111
8092.28 In reply to 8092.27
In Mode Object : Use Function Set Pivot Object or Manual Pivot with some Snaps then use Move/Rotate/Scale! :)
But go to Rocket Forum for more specific Question/Answer! :)
EDITED: 30 Oct 2016 by PILOU
8092.29 In reply to 8092.28
I can't see the pivot!
8092.30 In reply to 8092.29
Hum hum :)
Some Escape at the end of the Placement of the Pivot!
But please ask all that on the Rocket forum !
8092.31 In reply to 8092.30
I can set a pivot but I can't move objects - it moves by itself. will try your manual soon.
UPD: I found it! it is soooo tiny!
EDITED: 30 Oct 2016 by GLMR
New beta version 1.4
Principally the Spline Tool !
https://rocket3f.com/forum/updates/192-beta-1-4#1683
8092.33
Frenchy
If you also press the spacebar and scroll with the MW you can increase or decrease the amount of segments along the length of the spline. Really useful addition to Nvil/Rocket 3F
~Kevin~
8092.34 In reply to 8092.33
sure :)
New version beta 1.41
Random Selection
8092.36 In reply to 8092.35
Hi Pilou
Where do you get the bridge tools? I have been using rocket and in the latest version the bridge to 3d Coat and Moi are absent.
Best wishes
Keith
8092.37 In reply to 8092.36
Will come back surely in next versions! :)
8092.38
Rocket 3F crashes on my PC with i7 6700 and GTX 1060, but works on my old laptop. Any idea?
8092.39 In reply to 8092.38
Go to Rocket forum! ;)
Message 8092.40 deleted 31 Dec 2016 by MKDM
Hi everyone!
I intentionally deleted my previous post about Rocket3F because I'm not in the habit of place publicity of any software into forum of other software,
and I want to avoid any misunderstandings about that because I'm not linked in any way with its developers.
But I write these lines only for one reason :
Because I love every new software that like Moi is capable to break the barriers,
and i think that this newcomer into 3D modeler market can be a valid companion also for Moi's users
Well...with that said....
Finally the all brand new Poly/SDS modeler Rocket3F is on the market and the purchase should be activated soon.
It comes from Istonia, the creator of NVIL, and from Andrei Samardac for the streamlined workflow.
This is the web site : https://rocket3f.com/
And this is the official Youtube channel : https://www.youtube.com/channel/UCxJIYl9qcwyCSakhVC0vuvQ
I'm both an NVIL licensed user and a beta tester of R3F for a long time, and I must admit that it has won all my doubts about it.
It's ONLY a pure Poly/SDS modeler, that occupies a very small niche, nothing more, but what it does it does very well,
and it's especially focused on two things :
1) IMHO it has the best and fast workflow on the market (I have tried tons of Poly/SDS modeler right now from free to very expensive (in demo))
All the tools are designed for fast conceptual modelling
2) It has some absolutely unique features for Subivision Surface Modelling!
Look at this Youtube tutorials for its excellent Crease features : https://youtu.be/YhP784XnD-M
And it also have a very good built-in Bridge to :
- Moi : From <-> To. Look at this my very simple example : http://take.ms/iXgiO
For subdivision in Moi it leverages on the superb Max Smirnov SubD script.
- 3D-Coat : From <-> To
- KeyShot : Never tested because I haven't KeyShot
I think that now Moi has a valid counterpart about the best workflow :
Moi for Nurbs and R3F for Poly/SDS conceptual modelling.
Best,
EDITED: 31 Dec 2016 by MKDM
Message 8092.42 deleted 1 Jan 2017 by BEMFARMER
With the 1.43 bridges are come back! :)
(not for me because I have a little problem with my antivirus)
Else program works fine ! :)
Some tricks
Version 1.0 Released!
There is a free version with infinite month renew!
Funny that you promote so much Rocket3D here on the MoI forum.
I remember when you posted almost every day on the Silo Forum about MoI.
Maybe you should start also on the Rocket3F Forum a MoI thread, so that Andrej can appreciated it... :-)
8092.47 In reply to 8092.46
I promote generally only that it's free and complementary! :)
Show messages:  1-7  8-27  28-47  48-67  68-87  88-107  108-111
