Opinion about some good and robust Polygonal-SDS modeler under 200$
 1-3  4-23  24-43  44-63  64-79
8090.24 In reply to 8090.22
Hi adamio,
Thanks for your reply.
Well, I must admit that I already knew Rhino SDS project, and i made some tests with Rhino V6 Wip version,
but I you have to say that McNeel said the truth :(
Here's a couple of quotes of John_Brock at McNeel's forum :
"The SubD project is in the very early stages of development. It's just barely good enough to "throw it over the wall" to see if we're on the right track. That's how we get users involved in the development process. We are nowhere near the stage when tutorials are written. It isn't likely to be in V6. It will probably live in the WIP for a couple of releases before it's considered useful."
"A full Sub-D tool is a bigger project than you think. I don't expect it to be fully functioning for V7 either, but as we add the pieces and parts, they will be in the WIP and will progress."
Anyway, thanks for your suggestion.
8090.25 In reply to 8090.21
and thanks you very much for your reply.
> I do not myself use a sub-d modeling program regularly so I'd rely on other's advice more than mine for this.
Thanks for your frankness. Much appreciated :)
Regarding Metasequoia i must admit that I've never heard of it before...
Some minutes ago i downloaded the V4 trial version and I gave it a quick look.
What to say...seems to be very particular but as a first approach, I'm not so sure about it.
But i will give it a chance.
Thanks again and i wish you the best in your job!
Ciao.
8090.26 In reply to 8090.25
You don't speak about Neobarok! (A french guy again :D
https://neobarok.com (a fresh air on the classical other one)
A free modeler under steroïd! (seems this function not implemented on the version downloadable )
Neobarok :: Cables from Hypnothalamus on Vimeo.
8090.27
Maya LT is about 30$/month ... I hate subscription, and I'm not fan of big corporate, but the price/quality ratio for this one is difficult to beat.
8090.28 In reply to 8090.23
Thanks for the link to Glen Southern's tutorials.
I already knew them :)
Yes, with no dubt Silo is a mature software, but for me, comparison to NVIL it lacks in, at least, to main areas :
1) NVIL has the best tools for working with Edge creasing.
2) NVIL seems to be under very active development.
Anyway, thanks a lot, I appreciate your concern.
Ciao.
8090.29 In reply to 8090.28
<< 2) NVIL seems to be under very active development.
Sure it's more funny to code new thing or adapt old one!
NVil --> Rocket! You can't type on two keyboards on the same time! ;)
8090.30 In reply to 8090.29
Hi Marco,
Have you tried http://meshmixer.com/ ?
Ciao
Mik
8090.31 In reply to 8090.29
I'm testing Rocket3F and NVIL too...
Rocket3F seems to be a good modeler and i know that it is only at early beta stage, but there's at least three things that
don't convince me :
1) For the moment it misses too many features of its "father" NVIL
2) Although Samardac, on the Rocket3F forum and on NVIL forum, says that Rocket3F is a NEW product
that is separate from NVIL, i must say that this statement to be inaccurate.
For the moment Rocket3F seems nothing more then a NVIL with a make-up.
In fact i tried to run Rocket3F using all the configurations files of NVIL and...surprise....in front of me
I saw NVIL without the menu!!!
This thing confuses me and it doesn't make a good impression...
Certainly its workflow seems to be very, very good, like Moi, and this is a very important feature.
3) Like NVIL, on my laptop (i7 4790K 4.4 Ghz 32 Gb Ram, Nvidia Quadro K3100M 768 cores), it present the same
strange behavior. That is, an high and unjustified use of Cpu.
When i do any operation that involve the Rocket3F's viewport, the Cpu usage always jump to 15-22%,
and my laptop cooler always keep pumping.
Very annoying thing !
Silo for example is completely silent....
Nice day.
EDITED: 15 Sep 2016 by MKDM
8090.32 In reply to 8090.31
<< workflow seems to be very, very good, like Moi
Seems UI 's Moi found a school! ;)
Hi Mik (MIKULAS) and Pilou,
and thanks a lot for your suggestions.
Yea...I already knew all this products : MeshMixer, NeoBarok, etc...etc...
and I currently, often or occasionally, use all of them.
But I think that all those products, although they are with no doubt very powerful and very useful for some "exotic" or particular situations,
they can't be used for "standard" Poly/SDS modelling.
They can be rather a good companion to couple with a main modelling software.
For example i also use the fantastic MagicaVoxel (https://voxel.codeplex.com/), but it could never be my main modelling package...
Anyway, thanks to all.
Ciao.
And this exoctic very cool one! (my favorite) I made the French UI in the big long past! ;)
TopMod
https://www.viz.tamu.edu/faculty/ergun/research/topology/download.html
8090.35 In reply to 8090.34
Yeah! Sometimes i use also TopMod.
It's a very, very particular piece of software. For alchemists of 3D!
Ciao!
A free one more! :)
Formzfree : some usefull fonctions : like Stair, Rof, Terrain, Unfold volum Minutes 24.08
http://www.formz.com/products/formzfree.html
Export DAE, STL, KMZ so maybe some converters are needing! http://meshlab.sourceforge.net/
Works fine with MOI! ;) Thanks to Max Smirnov for the astonished _Import OBJ & _SubDiv_Beta9
EDITED: 15 Sep 2016 by PILOU
8090.37 In reply to 8090.21
Hi Michael and everyone!
I finally choose the Poly/SDS modeler under 200$ to include into my current workflow (Rhino+Moi+3DCoat+Thea Render).
After spending much garbage time, to test Silo NVil, Rocket3F and Metasequoia
(thanks a lot Michael because i didn't know Metasequoia and i must say that it was a good surprise), I decided to buy NVIL (for about 72 Euro).
I have just discarded Rocket3F because right now (IMHO) it's only a downgraded version of NVIL.
NVIL has a tons of modeling tools and its SDS capabilities a very good.
IMHO for the moment it lacks mainly in the viewport speed rendering, but its streamlined workflow allows to work
at speed of light!
And like Moi it's very deeply customizable.
Right now, it's the unique modeler that really can be compared to Moi regarding the streamlined workflow.
Anyway, considering that Metasequoia 4 EX costs about 150USD, i will continue to test it because it has some very interesting features,
like Armature, Blobs, and the support of the Pixar's OpenSubdiv.
Thanks to all for all your good advices and have a nice day.
8090.38 In reply to 8090.37
Bonne chance! :)
8090.39 In reply to 8090.38
Thanks and good experiments to you too!
I'm not afraid by NVIL's apparent complexity, I really appreciate its deep customization.
Anyway, I will continue to test Rocket3F and wait for next betas.
Ciao!
8090.40 In reply to 8090.39
After seen Rockect i am affraid of course by NVil! :) But It's because I am fan of SketchUp & Moi!
Wish for you that ZBrush Core has not less price than NVil! ;)
By Marco Splash
8090.41 In reply to 8090.40
No problem for me, because I don't like Zbrush and its workflow. :)
I suppose that this sentence may be seem a blasphemy...but I never liked ZBrush UI and its philosophy!
Instead I really appreciate 3DCoat and its voxels.
Rocket3F is a promising product but NVIL well customized it's fast and easy as Rocket, but with much, much more tools.
Ciao !
EDITED: 20 Sep 2016 by MKDM
8090.42 In reply to 8090.41
Yes but with some menus! Or some Shortcuts to memorise! Prefect for young brains! :)
Rockets where you have all in one glance has another philosophy!
8090.43 In reply to 8090.42
Pilou I agree with you regarding the headaches caused by shortcuts...
But i much prefer to spend some times to customize a powerful app like NVIL, as I did in Moi, instead have a fraction of the available tools...
But clearly this is a very personal opinion. :)
P.S.
3DCoat 9 minutes assembly and rendering. Very rough but ...9 minutes. From a model roughly downloaded from GrabCad library.
Robocop movie enemy.
http://take.ms/1TTjK
http://take.ms/T3cvx
Ciao.
Show messages:  1-3  4-23  24-43  44-63  64-79
