For SketchUp lovers :)
All  1-3  4-10
Trick is of course to draw an external more one component for more easy modification! ;)
Here the ground is a part of the box, but have not importance!
Only the 12 edges of the box are indispensable!
EDITED: 7 Sep 2016 by PILOU
With the free version
Maximum of the first Warp Box is 187 components !
After an hundred of components by Box
Seems number of Warp boxes is illimited (not verified)
A volume alone will not deformed by a "Wrap box" along edges if it has no section!
But will be deform on its faces (Translation, Rotation, Scale)
Activate Hide Geometry before using Section Tool!
Just Double-Click on a green edge!
Pie Menu By Rich O Brien
https://sketchucation.com/plugin/2477-piemenu
Seems free for the moment! Works from 2017 Make! ;)
8081.9 In reply to 8081.8
I truly wish there was a function or plugin in MOI3D to import Sketchup and FormZ native models.
8081.10 In reply to 8081.9
Hi Kenmo,
Sorry, neither is likely.
Sketchup files only contain polygon data, not smooth CAD surfaces or solids like MoI is designed to work with for modeling. Something that looks like a sphere in Sketchup is actually a whole bunch of little triangles, not a single sphere surface.
FormZ can contain either polygons or CAD solids but as far as I know it's not a publicly documented file format. So it would require an extremely time consuming reverse engineering analysis to figure out how the data is structured.
Show messages: All  1-3  4-10
