Replace Closed Curves With Circle
 1-4  5-21
8080.5 In reply to 8080.4
Gladly!
Wow ,from me too! Thank you very much!
8080.7
I just want to reiterate my appreciation.
This is the best software experience I've ever known.
Thank you Karsten helping with this.
Indeed thanks to all the wonderful people who make this forum so Great!
Special gratitude to Michael Gibson for empowering and inspiring such a vibrant community.
-- Mindset
8080.8 In reply to 8080.7
Thanks very much Mindset & Karsten too!
With what program is created the "half Tone" image of the first post ?
A free one ?
Message 8080.10 deleted 9 Sep 2016 by KMRQUS
8080.11 In reply to 8080.9
Frenchy,
The original attempt was via a Photoshop filter and traced to vector in Illustrator, but a better result was had from http://jasondorie.com/downloads/HalftonerV1.5.zip
The halftone Photoshop filter is of course raster based.
HalftonerV1.5 allows one to save in DXF, so the 'dots' are generated indeed as circles.
And YES, HalftonerV1.5 is free.
Hope this helps.
-- Mindset
PS, I thank you Frenchy Pilou for all your considerable contributions to this forum as well
8080.12 In reply to 8080.11
EDITED: 9 Sep 2016 by PILOU
About the CCWC above. (who is yet very cool)
It's transform any form of closed curves!
Does it not possible to input a factor or something else
for transform only closed curves who are more near arbitrarily a circle than an another form ?
(here one is a "J", other a rectangle (rounded))
8080.14
Hello,
Have you checked out Astute Graphics Phantasm plugin?
http://astutegraphics.com/software/phantasm/
8080.15 In reply to 8080.13
Hi Pilou, it's probably going to be difficult to make it behave like you're asking for there - computer programs generally can't just use human judgement to make decisions like that, they have to follow a detailed step-by-step algorithm.
If you can think of a more detailed set of rules that would result in the choices you show, then that could maybe be possible to translate into an algorithm.
But otherwise to just have it decide like a human would decide would need something like Artificial Intelligence to work.
8080.16 In reply to 8080.13
Hello Pilou,
I thought also about the problem and I agree with Michael. A simple, but very coarse filter would be to analyse boundingbox aspect ratio and the curve length in relationship to the absolute dimesions of the boundingbox.
And I have to note, the script CCWC isn't my project, it is an example to show the input parameters of the circle-factory in
Mindsets script! So I didn't tested it really.
Have a nice day
Karsten
p.s.: I have tried to implement gestures in MOIs scriptengine and it is a similar, but difficult problem.
http://moi3d.com/forum/index.php?webtag=MOI&msg=8078.6
EDITED: 10 Sep 2016 by KMRQUS
8080.17
Hello,
Does it possible to create a similar script that changes closed curves with circle to nearest integer value from the specific range? For example I type range from 2 to 6, curves closest to this values (from 1,51 to 6,50 in this case) are change with nearest integer value circle, assign any unique styles group by value and the rest outside the range are hide.
Sorry for my English, I hope it's understandable.
Thank you in advance for your help.
8080.18 In reply to 8080.17
Possible? I think Yes.
Augment the script with .htm file to select some or all closed curves,
and also to request the desired range of "dist" (dist = box.diagonalLength;), as distMin, and distMax.
distMin and distMax can be any value, not just integers.
Filter the selected closed curves with "dist", as follows:
If a closed curve's "dist" value is outside of the range, do not process that closed curve.
If a closed curve's "dist" value is inside the range, process that closed curve.
modify factory.setInput( 3, (Math.sqrt(dist*dist/2)/2));, by applying
Math.round(Math.sqrt(dist*dist/2)/2)),
or Math.ceil(), or Math.floor(),
to get the circle's radius in an integer value.
8080.19 In reply to 8080.18
Heh :-). Thank you Brian. I'm not a programmer but I understand idea and I'll try translate your helpful hints into a complete script. Trial and error method :-).
Marius
8080.20 In reply to 8080.19
Maybe combine and modify RCCWC.js, lineweb.js and lineweb.htm, and maybe some other script...
Looking forward to your new script.
8080.21 In reply to 8080.20
Math.round is best option but I had to move the closing bracket
from
to
Math.round(Math.sqrt(dist*dist/2))/2)
Thanks again :). I'm trying to take next step, but for me it is sci-fi :-D. Your support helped me a lot.
Marius
Show messages:  1-4  5-21
