How to line up elements
 1-2  3-22  23-31
8077.3 In reply to 8077.2
Yes!
8077.4 In reply to 8077.3
Same as the other guys :)
(Can't find a way to keep to middel chain elemets vertical :S)
Maybe you can make something with the free easy Algodoo ? ;) 2D
http://www.algodoo.com/
And the little less friendly but powerful solvespace (2D/3D)
http://solvespace.com/index.pl
8077.6
This is it! Intersection circles. Of course, of course. :-D
Love this forum. Thank you, guys!!
8077.7
@PaQ: In this setup (edit: with the REAL drag chain) it's impossible to keep the middle section vertical.
EDITED: 4 Sep 2016 by 3IMAGE
8077.8 In reply to 8077.7
Well it should look something like this ... but I can't find a way to snap the red segment on both circle :S
Hi PaQ,
i was thinking about the same and came up with doing a radial array of 360 segments on each circle to be able to trim then with more iterations following, but i'm still not there... :-)
EDITED: 30 Oct 2016 by STEFAN
Hello Pilou,
do you remember the free little program you posted once, it was a 2D animation program where you could draw/connect lines and animate them, like with Inverse Kinematics etc. ? I downloaded it once from your link and it was fun to play with, because it simulated the animation behavior exactly like real mechanical objects.
8077.11 In reply to 8077.10
That would be Algodoo, wouldn't it. He mentioned that already...
http://moi3d.com/forum/index.php?webtag=MOI&msg=8077.5
No, it wasn't Algodoo. Pilou showed also animation samples he has done with it.
8077.13 In reply to 8077.10
Yes I suppose that was Algodoo like Marco remarks! ;) (the more fun i have never seen)
Ah sorry cross posts!
So maybe SolveSpace
http://solvespace.com/index.pl is more the resolution itself!
https://www.geogebra.org/?ggbLang=en is entierelly for any geometric resolve
else maybe http://neobarok.com/
for this one i don't success to make the "animation" of these gears - we can because functions are well inside but...
Video is too speed! If you success I will be happy to know the trick! :)
I have made this one but can't move an individual object without break the link!
EDITED: 4 Sep 2016 by PILOU
unfortunately none of the programs you list. It was another program. Sorry i really can't remember the name.
You showed with this program connected straight lines and animated them, like real mechanical object behaviour.
The connected lines had little symbols between them for various animation purposes.
I already searched your forum posts today, but i could not find it.
8077.16 In reply to 8077.15
I will search in my repository! ;)
Curious is "little program"!
Do you remember if it was "on line" or not ?
Neobarok has this sort of thing but it's not in the" download" version!
This other one ?
http://animata.kibu.hu/
This ?
Yes, Pilou it is the Linkage program! Thanks a lot for your help, much appreciated!
http://blog.rectorsquid.com/linkage-mechanism-designer-and-simulator/
Best regards
8077.21 In reply to 8077.20
Cool! Same family than SolveSpace & Geogebra but only in 2D! :)
8077.22
Hello,
most of the parametric systems solves the problem and so FreeCAD also:-)
and you can EX/IM the skeleton by STEP.
A nice day to all
Karsten
EDITED: 22 Dec 2017 by KMRQUS
Show messages:  1-2  3-22  23-31
