How to line up elements
 1-12  13-31
8077.13 In reply to 8077.10
Yes I suppose that was Algodoo like Marco remarks! ;) (the more fun i have never seen)
Ah sorry cross posts!
So maybe SolveSpace
http://solvespace.com/index.pl is more the resolution itself!
https://www.geogebra.org/?ggbLang=en is entierelly for any geometric resolve
else maybe http://neobarok.com/
for this one i don't success to make the "animation" of these gears - we can because functions are well inside but...
Video is too speed! If you success I will be happy to know the trick! :)
I have made this one but can't move an individual object without break the link!
EDITED: 4 Sep 2016 by PILOU
unfortunately none of the programs you list. It was another program. Sorry i really can't remember the name.
You showed with this program connected straight lines and animated them, like real mechanical object behaviour.
The connected lines had little symbols between them for various animation purposes.
I already searched your forum posts today, but i could not find it.
8077.16 In reply to 8077.15
I will search in my repository! ;)
Curious is "little program"!
Do you remember if it was "on line" or not ?
Neobarok has this sort of thing but it's not in the" download" version!
This other one ?
http://animata.kibu.hu/
This ?
Yes, Pilou it is the Linkage program! Thanks a lot for your help, much appreciated!
http://blog.rectorsquid.com/linkage-mechanism-designer-and-simulator/
Best regards
8077.21 In reply to 8077.20
Cool! Same family than SolveSpace & Geogebra but only in 2D! :)
8077.22
Hello,
most of the parametric systems solves the problem and so FreeCAD also:-)
and you can EX/IM the skeleton by STEP.
A nice day to all
Karsten
EDITED: 22 Dec 2017 by KMRQUS
8077.23 In reply to 8077.22
Interesting.
Karsten, can you please provide the project file of FreeCAD?
8077.24 In reply to 8077.23
No problem.
Made with the last pre V0.17. Double-click under the model card on the left side the sketch.
Have a nice day
Karsten
EDITED: 6 Mar 2019 by KMRQUS
FreeCad forum became a real big one! FreeCad itself also! :)
Total posts 131062 • Total topics 13703 • Total members 9239
8077.26 In reply to 8077.24
Danke, Karsten :)
8077.27 In reply to 8077.8
"""""""""""Well it should look something like this ... but I can't find a way to snap the red segment on both circle :S """"""""""""
Hey PaQ,
It's going to be a complex calculation. transformation matrices can be created and used on 2 rigid bodies. (the circles work with a SINGLE coordinate system). But this situation brings into play "fixed positions AND the transform matrix). You could look at "Denavit-Hartenberg Notation" for a description of what's involved. So basically you would:
Create a coordinate system for the fixed objects and 2 more free form coordinate systems to plot points with the transform matix (I think its 2 coord systems with that many parts but I could be off by 1)
Then math would pick the points for each constraint coordinate, then plotted to the global "fixed" coordinate system...
lol....:o
It's another case where the Snap of the opposite moving segment B intersection with something will be fine!
Now we have only the base Move A of the segment "snapping" !
Sometime a trick can help, move symetric things and other but...
8077.29 In reply to 8077.28
Hi Pilou, unfortunately I don't think it's practical to add a snap like that which was always in effect, it would probably be very confusing if it snapped like that under regular movements.
Too many mysterious snap points happening automatically can be a problem.
Something like this will probably need to be set up with a constraint solver, SolveSpace is a good one to use for now. In the future I'd like to have one directly inside of MoI as well.
A manual construction! :)
Not perfect but...maybe sufficient for obtain the angles!
Redraw the Red segments 20
EDITED: 5 Sep 2016 by PILOU
8077.31 In reply to 8077.30
Very clever! A good solution in my opinion - pure geometry:-)
Karsten
(Steam locomotive - the older ones of us may remember ...)
EDITED: 5 Sep 2016 by KMRQUS
Show messages:  1-12  13-31
