Create curve from edge
Franz
31 Aug 2016 (1 of 9)
8075.1
I am a beginner in working MOI.
Is there a possibility to create curves from the edges from a existing surface, except by drawing?
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
31 Aug 2016 (2 of 9)
8075.2
Draw a Straight line or a curve above your volume
Then "Project" it Menu Construct / Curve / Project
http://moi3d.com/3.0/docs/moi_command_reference7.htm#project
Sorry I read your post too quickly! :)
My method if for obtain a curve from a surface! ;)
EDITED: 31 Aug 2016 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
amur (STEFAN)
31 Aug 2016 (3 of 9)
8075.3
if you copy and paste the edges you get curves.
some 3D doodles
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Message 8075.4 deleted 2 Sep 2016 by FRANZ
Franz
1 Sep 2016 (5 of 9)
8075.5
In reply to
8075.3
Thanks, it works.
Danke, funktioniert gut.
Sie haben tolle Sachen auf Ihrem Link.
Erstaunlich, was sich alles machen lässt...
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
amur (STEFAN)
1 Sep 2016 (6 of 9)
8075.6
In reply to
8075.5
You're welcome!
Gern geschehen!
Danke, mit etwas Übung und Fantasie kann man viele Sachen erstellen, die einem so im Kopf rumschwirren. :-)
P.S. du kannst "du" sagen, da wir uns alle hier im Forum dutzen.
Beste Grüße
some 3D doodles
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
1 Sep 2016 (7 of 9)
8075.7
In reply to
8075.6
To supplement, "joining" edges will also produce curves or lines.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
1 Sep 2016 (8 of 9)
8075.8
Construct/ Curves/ Iso make also curves perpendiculars from Surfaces! ;)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Franz
1 Sep 2016 (9 of 9)
8075.9
In reply to
8075.8
Thank you all, this things give a lot of new possibilities to make a funny modelling!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
