Relative scaling
All  1-8  9-10
8069.9 In reply to 8069.8
Hi Mike, so if Strata interprets the .obj file coordinates as being points, and you have your MoI units set to inches, you will need the coordinates scaled up by 72 in order for them to translate properly into Strata.
You can either do this by using the Transform > Scale command in MoI - select everything, run Transform > Scale, type in 0 and push Enter to specify the world origin as the scale origin point, and then type 72 and push enter. Then undo after you have finished the file export.
Or another way that is more convenient is to go to Options > OBJ options > "Scale factor" and put in a value of 72. Then that scale factor will be applied to every .obj format export.
8069.10 In reply to 8069.9
Thank you again.
Show messages: All  1-8  9-10
