Split Construct and Transform Panels
 1-16  17-28
8064.17 In reply to 8064.15
Thanks a lot Max!
@You : "...I added a line:..."
A neat trick :)
8064.18
Hi Max,
Many thanks in advance - unfortunately I have copied into this location and I cant get it to work.
C:\Users\lapkad\AppData\Roaming\Moi\startup
using win10 and MOI FEB release.
8064.19 In reply to 8064.18
Hi Alex.
@You : "...C:\Users\lapkad\AppData\Roaming\Moi\startup..."
Very strange...for me works flawlessly.
Ciao.
8064.20 In reply to 8064.18
Hi Alex, are you launching MoI by double clicking on a file or just launching it all by itself?
@Max - when MoI is launched and given a file to open, the file will be opened before startup scripts run and the pieces of the sidepane that holds the current filename will be different and so will yield a different length. So maybe get the length of the id="MiddleBody" element that won't include the current filename, or look at the SidePane.htm file directly instead of the dynamic HTML content...
8064.21 In reply to 8064.20
Hi Michael
it's the same for me on Mac
On Windows 7, using taskbar icon to start MoI4betaFeb2018, or double clicking on a .3dm file, the Feb 27_2018 version does not work, although the initial version did work, and the newer version works with the if line commented out.
On regular monitor, the two menus overlap, and must be alternately selected. Both or either can be minimized.
On my 4K monitor, both Draw/Edit and Construct/Transform menus show up in full, one above the other.
(I have Scene browser placed "adjacent")
There could be room for more icons on the 4K monitor...
8064.23
As bemfarmer reported starting new doc using startup icon or opening existing file same outcome.
Alex.
8064.24 In reply to 8064.23
Hi Alex, try editing the MiniSidepane.js file and removing that line that starts with "if" (the 2nd line in the file).
That should then work for the moment until an update can be done.
8064.25
Thanks for response between you and Max - make MOI the golden arrow in CAD. Have to say that layout mode is much more inline with modern screen resolutions and having the need to switch between pallets. The ol'mouse finger aint what it used be..
Awesome
8064.26
Hello all, I'm coming to this conversation a little late, so could someone tell me what I should do to have those panels separated with the latest beta (Jan-22-2020). I'm on Mac OS 10.15.3 Catalina, I am not familiar with scripting at all, and when trying to edit de SidePane.htm file with text edit, all I see is blank with no text at all…
Any help will be appreciated :)
8064.27 In reply to 8064.26
Hi marc, the easiest way for v4 is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9439.3
Some info on why this happens here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8330.3
8064.28 In reply to 8064.27
Thank you Michael, it works great. :)
Show messages:  1-16  17-28
