SWEEP->SCAILING RAIL -> CANCEL
805.1
I select a profile, then two rails then by accident I press "Select scaling rail" and I find out that there is no way to go back, the cancel button cancels the sweep command... I guess it should go to the previous screen, not cancel the command. Easy to fix yes?
***There is always a better way to do things... Just find your Moment of Inspiration***
805.2 In reply to 805.1
Hi JTB, thanks for reporting this.
Yes, I think you're right, it would be better for canceling in this situation to just bail out only of picking the scaling rail instead of exiting sweep entirely.
> Easy to fix yes?
Yup, this one is easy, so I have tuned it up for the next release.
Thanks!
