Hi Surfnturf,
> 1- Like Rhino is there any chance for Grasshopper to be a plugin of MoI ?
Sorry, no chance of that. Grasshopper is a complex plug-in that runs inside the Rhino environment, it's uses all kinds of services in Rhino which makes it tightly connected to Rhino. Although MoI has similarities to Rhino it's not an exact same replicated environment and so you can't run a Rhino plug-in inside of MoI.
As an analogy think about a car engine part and how it has all kinds of hookups to other systems in the car - and then you're basically asking if you can just take one part from one car and just drop it right into place in a totally different car model.
> 2- Do you have in mind to create an own MoI node language ?
I don't myself, but someone else already has! Check out this thread here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3145.28
In the future I would also like to try and incorporate some kind of procedural model construction more directly supported in MoI but probably more text scripting focused than node editor focused.
