Hi Chri, thanks very much for the examples!
So if I understand correctly, you're currently getting this done by setting up that diamond with 9 copied objects in it and then applying the proper rotations to each object?
Would it perhaps be better to automate that object copying and transformation process with a command that generated 9 objects from one, rather than having it do Make2D output only? Because then you'd have a few more options like being able to export to PDF or AI format to get the shaded background underlay, or doing Make2D on the Top view in just one more step... ?
Also for your methodology, how is the size of the diamond determined?
