desoldering summit
8039.1
Hello,
I have a little problem when i try to export in .obj
software that i use after ,do not see the separation
My question : how to ensure that the part is not welded ( when export )
the two rounded part in the picture, each requires their own point ( is showed welded :/ )
need cutting or something ?
je voudrais simplement que chacun des "tubes" ne soient pas souder qu'il aient chacun leurs propre point aux extrémités.
(c'est le résultat d'une extrusion en suivant une ligne )
EDITED: 24 Jul 2016 by DZEKO
Size: 192.9 KB, Downloaded: 25 times, Dimensions: 889x754px
8039.2 In reply to 8039.1
Hi Dzeko, if I am understanding you correctly, you want a polygon structure where each polygon on either side of a common edge in MoI will have its own vertices stacked on top of their neighboring ones rather than sharing a single vertex?
That can be controlled during your export from MoI, uncheck the "Weld vertices along edges" option in the expanded Meshing options dialog here:
8039.3
thank you Michael.G
