no blend and unable to make surface on unplanar closed line
All  1-3  4-5
8033.4 In reply to 8033.1
Salut Dzeko,
La tracé doit être plat (et fermé) pour pouvoir créer un plan.
Sélectionne le tracé fautif, clique sur ses dimensions (en haut, à droite), décoche "maintenir proportions", puis change la valeur de y pour 0.
Le tracé deviendra plat.
Tu pourrais aussi redimensionner à 0 en Y avec la souris par la vue de haut ou de droite.
Avec la commande Déformer, tu pourrais ensuite faire courber le plan.
Your path must be flat (and closed) in order to create a plane.
Selec the faulty path,
clic on its dimensions (left top corner of the window, below the style name),
uncheck the "Maintain Proportions" box,
then enter 0 as Y value.
You could also resize the selection to 0 with the mouse in the top or right view.
Your path will become flat. You could then use the Flow-Deform command to bend the shape.
Michel
EDITED: 21 Jul 2016 by VINC
8033.5 In reply to 8033.1
Hi Dzeko - one way that could possibly work for you in MoI would be to start with your planar curve, then run Draw solid > Plane to make a plane that closely hugs the outline, then run Edit > Add pt on that plane and insert some control points on the plane so there are some points localized in that general area, then use Edit > Trim to cut the plane with the outline. Now you can use Edit > Show pts on the trimmed surface and it will have that same control point structure and you can turn on surface control points using Edit > Show pts and move and rotate just the corner points to warp the surface:
Hope that will work for you,
Show messages: All  1-3  4-5
